Woke up this morning to a complete signal loss on both receivers. Tried a check switch and both failed. Does this sound like a complete LNB failure?
Are all channels affected? Reason I ask is that my locals are gone (77 degrees), and that message comes up when I go to one of those channels. Using the program guide via main menu, I can see the other channels.
Yes, all channels. I cannot access program guide. I have tried check switch, hard reboot, reset, etc. It is strange that it just quit working this morning.
what dish do you have?Depending on the model of your dish the prices vary.Anywhere from $15 to $40.If you can tell me the type dish you have I can be more specific with the price.
1000.2
Same thing happened to me this morning with my 722 but it is ONLY on tuner 1 (the HD tuner). I can see everything on tuner 2 - all test come out to be fine and no leaves in the way unless a tree moved over 5 feet. I moved the HDMI cable to all ports on the TV and still the same.
It was a complete lnb failure. Replaced it and all is working.
Limited time offer
