I have had (purchased or under warranty purchased) 7 or 8 622s since Febuary of the year they were released. I have had this issue on most of the units hooked up to my CRT RP HD ready set. After one of Dish's upgrades over a year ago, my HDMI/DVI cable has no longer worked. As it is an analog TV that isn't an issue for me. The problem has been the loss of component out. When it happens, it has always been the day after turning off the 622, while using the OTA tuner. In every case, but one I've restored the component via a soft or hard reboot. That exception was Tuesday. Monday I lost component out audio worked fine, composit worke fine reset didn't work. Tuesday same situation, also tried other inputs on tv and different cables. Called tech support, first person after a little time on phone, asked me to wait a moment, I hung up 5 minutes later. Second person went through all the checks again asked me to wait a moment, 5 minutes later I hung up. Third person and I'm steaming, (American for the first time) we go through the whole routine again, I explain my issue with this being the 4th unit since March (others died) and I was getting fed up with refurbs. He stated a service call was necessary. Cancelled this morning---component has worked without an changes in hookup for 2 days. Any ideas?
