At times its prohibitive to cut a Compression Connector from a coax to remove it from a Switch Weather Box, since the coax becomes too short and would need all be replaced. Is there a Compression Connector Removal Tool? Or, how otherwise such Connector can be removed without damaging the coax? Can removed by such Tool compression connectors be reused - it doesn't make sence to throw away a whole bunch of these for no objective reason?
