Config question | SatelliteGuys.US
Config question
herzzreh
61
Hi... I'd like to set-up as described below (sorry about sh!tty ascii graphics). Would this work? a/v cable run would be about 50 ft.
legend: ^ = TUNER 2 A/V cable; --- = TUNER 1 COAX; ### = TUNER 2 COAX
|322|-----|REPLAYTV|---------|TV1 S-VIDEON IN|
^ ####################|TV1 COAX IN|
^^^^^^^^^^^^^^^^^^^^^| TV2 A/V IN(bedroom)|
the fifty foot run, might cause you some problems. i believe you will be watching the same thing on the tv1 coax and the tv2 av, if i am reading your picture correctly.
Yes. Reason I want to run a/v is because 322 doesn't have the stereo output on 2nd tuner coax out.
Iceberg said:
but if you use the a/v output, that is for TV1 only
arrgh... I didn't realize 322 doesn't have tv2 a/v output. I thought it was like the 522...
***edit*** Just looked, 322 does have both RF and a/v tv2 outputs.
The 322 DOES have RCA outputs for BOTH TV1 and TV2.
(Iceberg thanks for making me go and look) :D
CSTV Now on Dish Channel 152
Is this possible if I have DISH?
