Confused newbie | SatelliteGuys.US
Confused newbie
Avcomm
17
Livermore, CA
Hi all. First post here. From what I've read so far, this is THE place to be for FTA!! OK, I have a Traxis 3500 and I have tried to aim the dish at G10 without any luck. The main problem is, I am pointed at something, but when I do a blind search, the TP freq, VPID etc don't match anything from lyngsat. The found list comes back "$no name" and on the preview screen it says "scrambled". I would think I hit a Dish or Direct bird, but again the TP freq, VPID numbers don't match anything. Any ideas?
Ken
Welcome to Satellite Guys U.S.
In order to help you better.
What size dish are you using ?
What Type of LNB are you using ?
Hold on, I got your PM.
EDIT - Your on Anik F3 at 118.8°W or EchoStar 9 at 121.0°W
Let me try to narrow it down.
EDIT - You are most likely at 118.8°W :)
Thanks. I won't be able to move it till this week-end, but it sounds like all of the hardware is working.
a Universal LNB will work for all linear satellites like G10.
The difference between a Universal and a standard LNB is the frequency range it can pick up. Here in the US the only satellites that need a Universal are a couple of the satellites over the Atlantic (PAS9 & PAS1R). But you can use a Universal for all the other satellites too
Frequency range of a Universal....10700-12750
Frequency range of a Standard....11700-12200
OK, thanks. I guess I'll need to go back and study the FAQs.
Still confused about what L.O. means and why a Universal LNB will work since:
Standard KU LNB's use an L.O. of 10750
Universal KU LNB's use an L.O. of 9750-10600
LO = Local Oscillator (Technical term)
In the US the frequency range used by linear FTA is 11700 - 12200, the standard LNB only covers that, the universal covers that in the upper band.
Universal LNB
Lower band: (10700 - 11700)
Upper band: (11700 - 12750)
Found a dish
Pbs Ac3
