Connect 2 TV's to an HR-24 Receiver - 1 HDMI, 1 Coaxial | SatelliteGuys.US
Fairway Fatty
21
Va
Can I connect 2 TV's to an HR-24 Receiver? 1 is HDMI, 1 will be Coaxial
The second TV is in an adjacent room so all I have to feed it from the receiver will be a Coax. I realize the 2nd TV will not be getting HD feed.
Any help is appreciated.
FF
Yes, to do coax you will need an RF modulator (or old VCR).
I use HDMI and component together on several of my boxes.
Just be aware that the aspect ratio will be the same on both displays.
Depending upon the hook-ups on your second TV their are different ways to go. You can buy an HDMI splitter and cable and do it that way. You can go component cable from DVR to second TV and you won't have HDCP issues. Or you can go composite cables with an RF modulator to run a coaxial cable. With the coaxial and composite hook-up you will have to switch to 480 to address the HDCP issue.
3D channels
New Dish?
