connect MRV to router with cascaded splitters? | SatelliteGuys.US
walendvay
45
I have 6 tuners (2 HR24 DVRs and 2 H24 standalone receivers) all with their dedicated lines from a 1x8 SWM "green labeled" splitter. Can I connect the system to my network with the following approach.
dish----swm 1x8--------swm 1x2--------H24
--------------DECA+pwr supply-------router
I don't want to run another cable from my 1x8, which is located outside.
Sorry if this is explained some other place..... I couldn't find a post about it.
thanks.
the DECA+pwr supply exits the 1x2. for some reason, my posting above didn't come out correctly
-----swm 1x2------H24
.........----------------DECA + pwr-------router
perfect. thanks for the help!
yep, all of my unused 1x8 ports are terminated. without them, I am sure the reflections on the coax will reduce signal margin significantly.
Cant record a sports channel?
DVR canceling programs by itself!
