Connect two 9241's with an sw44 switch | SatelliteGuys.US
bcondemi
canada
Sorry but been looking for an answer for days now....I hope I'm in the right place....
I have now a 2 dual lnb's and an sw44 switch (all 4 cables are connected). 1 and 2 are connected to my first 9241. I just got another 9241 and connected 3 and 4. however, I can't get the reciever to get both satellites? What is the correct cable connections and will the sw44 work for this setup?
BC
Nothing wrong with the way it is wired but I would check the connectors and the cable to the 2nd 9241. Don't forget to run a check switch. Look for old cable splitters on the cables too.
that should work, do you have the power inserter connected to port one?
sounds like a bad cable or connector/cable end
Do you have both cables from either 82W or 91W going to 1a & 1b and the other satellite position on 2a & 2b? You cannot cross over the satellite positions between 1 & 2 on the input side.
