I just picked up a satworks 3618 and i am trying to figure out how to connect it with my analog c/ku reciever. The analog reciever is a drake 1724, and is about 10 years old, so i dont think diseqc is part of its vocabulary.
I was told to "slave" the satworks to the drake, but i am unsure how to do it.
The drake does not have a loop out feature. The only coax outputs are tv out and 140 mhz out/ in. The manual says that the 140 mhz is for a TI filter. There is a composite output for othere descramblers (the manual said MAC?) The inputs for the drake include seperate inputs for both c and ku band lmbs. The drake receiver is what i will be using to position my dish.
The satworks 3618 on the other hand has loop out coax, but only has 1 lnb input, and is incapable of positioning my dish.
So here is my question. How do i connect a dual lnb system to work seemlessly with both the satworks (dvb) and the drake (analog)? i am sure i need some switches, but am unsure as to the "who, what, when, where and why" of it all.
I did manage to get my dish pole mount set up this weekend, just so ya'll know two 40 gallon barrels welded together need 17 80# bags of concrete to fill
Now i am just waiting for the concrete to cure and i can actually put my pole and dish up, which i will probably do next sunday. Then the real fun begins
