Controlling 510 receiver with 6.3 IR/UHF Pro remote | SatelliteGuys.US
JRF61
5
Hello,
I recently received a new 6.3 Pro remote for my 510 receiver.
I coded it for the TV, however, I can not get it to control the sate. receiver.
Could someone please give some instructions as to what I need to do.
Thanks in advance.
JRF
On the front panel of the receiver go into the menu then you want to goto 6-1-3. After you get there make sure you have the remote in sat mode, and press the record button. This should get the receiver on the right frequency.
Also, don't forget to switch the tab on the bottom of the remote from the blue 2 UHF Pro to the black UHF. The remote will not control the 510 with the tab in the UHF Pro position.
DVD player connection
mlb network
