coolsat 4000 pro question | SatelliteGuys.US
rotor
14
Was wondering if a good old Dish 500 will work or a old Primestar dish will work for the coolsat receiver? I am new to FTA but, not cband. New for a "old" guy. :rolleyes: To get the USA free stuff, will I also need a rotor? :eek:
Hello and WELCOME to the SatelliteGuys.US FTA forum :welcome
You can get a few TV channels and Radio using an 18" dish.
http://www.satelliteguys.us/showthread.php?p=534104#post534104
A Primestar dish and LNBF will work for all the KU FTA signals up there!
A motor is a great idea as it will let you pick up ALL the KU satellites up there (depending on your view to the satellites) . I would not waste time motorizing a Dish 500, but a Primestar Dish will work with some modifications to remove as much weight as possible.
http://www.satelliteguys.us/showthread.php?t=42450&highlight=Primestar+mount
Thanks! you are the genius! Also, will the Primestar dish work ok if I mount a dual lnb legacy on it to get more channels? I might be stupid but, it is fun!
A lot of members simply zip tie a Dishnetwork or DirecTV LNB to the Primestar (KU) LNBF and then you would be able to get both linear and circular polarized satellites, the best of both worlds.
viacast quantum msr 1500
newbie help me please
