Coolsat KU LNBF | SatelliteGuys.US
Coolsat KU LNBF
GMARCA
13
West Hartford Ct, USA
Hello again
im am using a coolsat KU band lnbf with my 120cm fortec star dish wandering can i get any C band sats or i need a special LNBF for C band that fit my dish
Sorry again im still new to this Thank you in advance :confused:
Yes you will need a C-Band LNBF. There are some that are made for off set dish and others like the ASC-421 that are really made for prime focus dish.
Check out Eye In the Sky - They have a C-Band LNBF that is designed for offset dishes. I have one and I think it works a bit better than the prime focus LNBF's.
Ka Band?
help to setup my dish with motor
