Coolsat Pro Settings for DirecTV 1R/2/4S | SatelliteGuys.US
PopcornNMore
3,635
128
Gibsonia, PA
What are the correct settings for the Coolsat 4000 Pro to receive the two FTA audio channels on DirecTV 1R/2/4S?
I believe I should select SINGLE for the LNB TYPE, but what are the other settings?
I have a high quality level, but during a scan it found nothing.
Thank You,
Dave
Won't work
DirecTv uses a different scrambling technology than DVB...only DBS audio on Dish or ExpressVu
DirecTV also use a different system so there are NO FTA/In The Clear channels from DirecTV.............unless you have an active DirecTV receiver then you will get the free movie weekends.............but thats it!
Defective LNB? DMS DVB321-2
Anyone upgrade to the Pansat 2700?
