Coolsat won't Blind Scan | SatelliteGuys.US
phpinfo
294
USA
For some reason the Coolsat 6000 won't blind scan anymore. It just shows zeros for the TP and stays at zero percent.
I tried updating the firmware, but that didn't fix the problem.
I was able to blind scan previously, but now cannot. I can auto and manual scan though. Any ideas?
I think I figured it out. There are duplicate TPs that were input from an NDF editor. The Coolsat won't allow duplicate TPs if you are manually entering them on the TV. But if you send a channel list from the computer with duplicate TPs, it will take them but then mess the Coolsat up if you blind scan.
Just noticed this post. I had the same problem before on a 6000 and for me it was the same fix. Glad you were able to get it worked out quickly!
Byron
Scored a free PrimeStar today!
7" LCD TV $49.97 at hhgregg
