Correct way to split signal for two recievers? | SatelliteGuys.US
manowell
28
7
Dallas, TX
This is for a RV install, replacing DirecTV. I have all of the DirecTV stuff disconnected.
Using the supplied diplexer I can get the first TV to work fine with the RV's amplified roof top antenna and Orby dish connected. no matter where I split the signal from the Orby dish, it seems, when I power up the second DVR the first one puts up a "satellite signal lost" error. If I unplug the second unit, the first one comes back.
What am I missing?
From other posts a high frequency splitter but some of us are using a 3x4 multiswitch mini and just the 13v side.
I've tried the high-frequency splitters, that's where I'm at now. No matter where I install it's either "A" or "B". I'm ordering the Eagle Aspen 3x4 multiswitch, too.
You should be fine if you use a multiswitch. I am driving four Orby receivers with just a modded DirecTV Slimline (mounted on pole above my motorized Fortec Star 90cm FTA dish) and a Zinwell SAM-3402 multiswitch. Also feeding my combined VHF/UHF antennas into the multiswitch and all four receivers can tune Orby and OTA channels just fine. :)
IMG_6412B.JPG Orby Hookup 2.JPG (Thumbnailed - Click for larger)
