Coship CDVB5300B | SatelliteGuys.US
Coship CDVB5300B
PilotS77
SatelliteGuys Guru
138
Is the Coship CDVB5300B a USALS receiver? Will it drive an SG-2100??
Coship
I have a Coship 5300B and I have had pretty good luck at moving my dish. Biggest aggrevation is manually entering the sat addresses. My firmware has been updated once. It sits in a box now since I bought a Fortec Ultra. What a difference! Blind search, USALS, you name it. :)
M.J. courtroom footage on amc-5
Help! Problem with Using Switch and Motor
