cost to reinstall direct Dish on new roof? | SatelliteGuys.US
northpointe
10
Stratford, Ontario
Hi. Need new roof and my Direct TV dish is on the roof. I have vinyl siding so can't mount it on the side of the house. How much will Direct TV charge to come and reinstall the dish?
Yes, if you are really in Canada, DirecTV won't come out at all because DirecTV is not available in Canada, in fact it is illegal. You will probably be able to find a local satellite installer who will come out and do the work for you.
If you call DirecTV about this they will cancel your service.
Assuming the mast is plumb now, reinstall it plumb and you should be able to align the dish easily by turning it slowly until you get a strong signal. Use the meter in the receiver/dvr and you will be fine.
If you have the protection plan call an say a storm blew it off the roof and you need a new one installed.
h44 genie says insert valid access card
DIRECTV Applauds Time Warner Cable For Fighting Back In Dispute with CBS
