Couple of questions about the QPH-031 | SatelliteGuys.US
LordAlex
SatelliteGuys Guru
132
Hi guys and ...gals?
I read a thread on here, but cannot find it, about setting a "port" number in the receiver's antenna setup in reference to what port on the DISEqC switch that sat will be coming through. I didn't see that info in the antenna setup on my 3500.
Secondly, my -301 casing is not well sealed down the center line. I can push the two sides together an close the gap. Should I put some adhesive in there before it goes out into the weather?
Lastly, any problems using a 4x1 switch if the unused two are terminated?
Thanks !:hatsoff:
4x1 will work, good idea to terminate :)
I usually crack open all my LNB's the casing is just that, its not a water seal!
It has four outputs 2 x C and 2 x L.
On my Traxis DBS 3500 I have port 1 for Linear and Port 2 for Circular!
Ok so you do need to know the ports for circular vs linear sats...where does that info show up in your traxxis? I didn't see it in my 3500.
Receivers do not differentiate between circular and linear signals, its up to you to remember what one is what!
I set the ports under................... DiSEqC
Right Hand = Vertical
Left Hand = Horizontal
When I said "see" I meant set. Thanks, it was DiSEqC on mine too.
Now as for H or V TP #1 is always showing when go to add a sat with V or H showing...do I need to set it anywhere else before I start trying to get quality readings?
Need, DFreq. / Polarity / Symbol Rate of a LIVE TP. before you will start to see signal quality!
Stab Hh 90 ????
4:2:2
