Couple of simple ? on DVBDream. | SatelliteGuys.US
delta_charlie
716
153
Hi all, just got DVBDream version 1.4i working :)
Just a couple simple questions, Can it run full screen? If so how - what command or menu?
When I installed it I saw an option for two audio drivers. One was Direct x and the other was my Realtek HD audio. I selected Direct X and it is working fine but I would like to try The Realtek HD audio. Any way to reset this after the install?
Thanks, DC
If you double click on the picture, it should expand to fullscreen. As for changing sound options, I'm not sure but you could always un-install, then re-install with the different choice, it only takes a few minutes to re-install.
Edit: In dvbdream, select options, video, then in the drop down box next to audio renderer you should be able to choose your audio source.
Looking to enhance my TV viewing
Unreliable Sources
