CP and LP Help | SatelliteGuys.US
CP and LP Help
mikemay
5
Hi is it possible to get CP and LP signaled satellites with the Toroidal T-55
I am a subscriber to Bell Expressvu and want to know if I can use FTA as
well as Expressvu with the t-55? I am assuming I will need two different
LNB's do do this if I can? I have a Coolsat 5000 and a Bell Expressvu box. So I want to use Expressvu and FTA off one Toroidal T-55
ah ok thanks maybe I could do this also with a quad polar lnb and one motor :confused:
Yes, thats what I use, but of course then you are stuck on one satellite position at a time.
PSB ok thanks:D What size of dish could I use to do this with the motor if you could suggest one that would be great? The smallest that would work? and I guess the motor a some kind of remote switch to change birds right? I am kinda new to this whole thing.
Thanks:D
I am in MN. USA and use a 36" dish and Invacom QPH-031
If you can find one a 1m dish would be great! Everything is controled by the receiver, so all you need is a dish a KU LNBF the receiver and a motor.
One cable goes from the receiver to the motor from there to a 2 way/or 4 way switch then 2 (or 4) cables to the LNBF.
Ya just found that one :) Hay PSB what motor are you using with your dish is the SG2100 DiSEqC motor a good choice
Please help to get good signal(pansat3500s)
Advice: Traxis 2500 vs Coolsat 5000
