crazy canadian newb | SatelliteGuys.US
crazy canadian newb
brotherhood
397
97w/55n
i would like to get the portugese channel (rtpi)
what do i need for a reciever and dish ?
got a dishnet pan and lnb ,dont care about the other channels
doing this on the cheap
thank you for your time
Hello, any basic KU FTA MPEG2 DVB system will pick up RTPI on AMC-4, you may need a slightly bigger dish than a standard 30" dish, but its a great channel and I have seen one or two soccer games there. Check the link below for the coordinates....
http://www.lyngsat.com/amc4.html
( RTP Internacional 12169 / H / 3003 )
hi all from canada
thank you for the fast reply ,is there a newbie installers Guide ,so i can install it right and what satellite to point at etc.
thank you again
Let me know what BIG city you are near and I can give you all the angles you need to point your dish at the AMC-4 satellite, its at the 101 deg. orbital position exactly the same place where DirecTV's main satellite is! (your dishnetwork dish will not work for RTPI)
You would enter the coordinates I gave you in my first post into the receiver point the dish using the angles supplied and you should soon find the satellite, there are plenty of tips and hints here at the FTA forum, and all the guys here will help you get set up, good luck.
u guys rock
i live close to winnipeg manitoba canada about 8 hours away,its a gift for my parents,so they can watch there homeland .
thank you again all
you're just up the road from myself & Pete (well, a long ass haul from Minneapolis) :)
According to http://sadoun.com/Sat/Installation/Satellite-Heading-Calculator.htm
you would set the dish as such
elevation 32.7
azimuth 174.7 (including -10 for deviation)
skew (tilt on the LNB) 3.2 to the right
The link you can put your latitude/longitude and you'll get a little better coordinates if your outside of the Peg :) (listening to Power 97 out of there...love the station) :D
holy crap...you ain't kidding...you are pretty far way from Winnipeg
Looking at a mp, your azimuth would be the same...your elevation will be a little lower
Since the link I provided doesnt do postal codes, it might be a little tougher, unles you know your latitude & longitude.
brotherhood said:
i live in thompson manitoba if that helps
I just went to another site, and there are only 4 stations there?
CBC
Radio Canada French
Native radio
Arctic radio...that one sounds funny
damn...not much for variety...you might want to hook that directTv dish up to 91 for expressvu. There are some radio stations on there :)
thank for all the help people
ya pretty far and being new at this does not help ,is there a good place to buy complete systems in canada or states
parents are going out of town and would like to Surprise them when they get back.
thank you
hi all
Equity Stations on G10, possibility of HD channels?
