Creating Avatar | SatelliteGuys.US
Creating Avatar
Not open for further replies.
jrrdy1380
39
Virginia
I love the avatars that many of the members have. I would like one under my name when I post something. How do I go about this? Is there something out there that has some avatars already made or are there templates and/or instructions on how to do this correctly?
I just found a picture that I like and then reduced the size to 100x100 pixels. Then under your user cp you can upload your picture. It was a lot easier then I thought it was going to be.
Hope that helps.
Shawn
Hope that helps.
Shawn
Yeah, like he said! You can use any picture your little heart desires. I just used one of my baby pics.
;) :D
I must be missing something. When I click on edit avatar on user cp. There is no option to upload an avatar. There is a button which is selected, that I can not unselect, that says do not use an avatar. There is also a save changes button and a reset fields button which also has no affect.
Let me check the setup, it could be a case I didnt setup something correctly with your moderator account. :)
