Cross Reference Chart | SatelliteGuys.US
beavs2112
Addicted to Legal FTA
814
248
London Ontario Canada
Hi all.
I was doing some research on buried cable and compression connectors for my new FTA system. I did a search on this forum for the connector part numbers for RG-11 buried cable but came up empty. A rep from Ideal Industries sent me this connector and cable cross reference chart. Use at your own discretion since i cannot verify all the info contained. I am not trying to endorse Ideal I just thought it might save some other members some grief finding out the cable and connectors they have don't match up. I did receive e-mail permission from the Ideal sales rep to share the file.
Regards.
Interesting chart, there has been big discussions on compression fitting in this forum but actually they have never been my main concern. I'm sure Anole will come up with a reference on that.
My view is that the cable is more important and when I buy coax I deem these the most important factors.
1 the centre conductor must be copper and not copper plated steel.
2 the shield foil should be copper and not aluminium
3 the shield mesh should be a dense weave.
4 the dielectric should be solid not air spaced
I do not believe in direct burial despite what the manufacturers might say since sched 40 tube with glued joints throughout is relatively cheap and so much easier to re thread and add more cables. In fact Canada has different burial rules to the US and you can use flexible plastic pipe whic is even cheaper and easier.
I use cable made in the USA and Italy since their manufacturing standards and quality are far superior . Buying cable manufactured in China is a sheer waste of money. The losses and variable specific resistance in these cables can be ridiculous. We all strive to get the best from our equipment so why add a negative factor with second rate cable. I have tested many manufacturers cables in both Michigan's winter and Cyprus' summer and certainly the heat is the most damaging causing the outer casing to degrade and become porous over time usualy 4/5 years. For some reason China seem unable to make decent plastic or rubber (don't even try their tires) and their cable due to many problems is no longer imported into Cyprus or other countries in the EU.
ive never paid that much attention to my coax before. can you pm me a manufacturers link or an estore that ships good cable to canada ? thanks.
crackt out,.
Mike > Your teacher must have had a brother my side of the pond. Hope you had a good holiday
Seriously it amazes me how some people will spend a fortune on LNBs for minor gains when their cable looses 15dBuV over 100 feet
Hi Pedro,
It was very cold in Florida this year, I had two warm pool days out of 28 days.
I did pick up my 1.2 Prodelin dish from General Dynamics SATCOM Technologies warehouse in Newton, NC. Here are a couple of pictures of their products that were in the back of the warehouse. I purchased the 1130 RO/dish, check out the spec's.
http://www.gdsatcom.com/Antennas/Data_Sheets/76-1-12ro.pdf
Can't get Maxpeak to see anything.
local oscillator info
