M MDUB New Member Original poster Jan 15, 2007 3 0 Jan 20, 2007 #1 Can anyone verify the current phone number for Directv's customer retention line? Also, will I need a pin? I called a number and it asked for a pin. Thanks.
F FavreJL04 SatelliteGuys Pro Jul 14, 2006 166 0 Jan 20, 2007 #2 I don't know the number, but it does require a pin now. The pin is only good for 5 days.
M mtsz52784 SatelliteGuys Family Jun 25, 2006 57 0 Tonawanda Jan 20, 2007 #3 USE the search tool... you will notice that this has come up for a couple months now...
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,078 8,435 NW Ohio - Buckeye Country Jan 20, 2007 #4 mtsz52784 said: USE the search tool... you will notice that this has come up for a couple months now... Click to expand... But the old pin number no longer works... (the original one anyways) I just call the regular number and ask for the dept. you want. Jimbo
