Custom Folder in My Recordings | SatelliteGuys.US
BBCInc
On the dry and dusty road
470
18
Colorado
Getting used to my new Hopper... So far I can't figure out a way to add a custom folder to My Recordings. I have quite a few recordings that were under "Cooking" on my 722 but were separated out when transferred via EHD. Is there a way to put them in a folder called "Cooking" on the Hopper?
In recordings....Edit/select shows/edit action...send to folder/select folder or create new one.
While that works, can't say I'm thrilled with the result. With the limitations of the view choices there is no way to emulate the way DVR recordings were displayed by the 722, where moving a file removed it from the current view and placed it in the (sub)folder. For the same reason, adding a list view to the current Hopper GUI will not be trivial, IMO.
722k rebooting continuously!
Icons on Ext Hard Drive recordings
