Custom Pole Mounts | SatelliteGuys.US
Custom Pole Mounts
Mikey11
858
16
canada
is there a section anywhere that shows some custom pole mounts?
for one of my future installs i am going to need to mount a 2-3 inch pipe onto a brick wall (spaced out from the brick) not sure how to go about this,
it is a motor install so needs to be level also,
if there is no section for this maybe some of you can help me out with some pics?
thanks
How far out from the brick does it need to be? If it's only an inch or two, you could use Unistrut and Unistrut pipe clamps pretty easy to do that....
My installation uses Unistrut and U-bolts...
Here is a link to a wall mount made for a 1.8m.
I guess you could downsize this idea for your dish.
http://www.satelliteguys.us/free-ai...alling-6-footer-up-side-wall.html#post2079394
Or you could use a standard 'S' type mount with struts for stability.
MM3 PV Perfect Vision Minimount For Outdoor Antenna
thanks alot, you just reminded me that i HAVE an old "S" mount that im not using anymore, im just wondering what you would recommend using for stabilizers/struts?
thanks, that is a great idea too, im just wondering how you would make sure the pole is level? if the wall is not exactly level how would you level the pole?
Can't find signal with miniBUD
Polarity question
