Cut Antenna cable | SatelliteGuys.US
Cut Antenna cable
ml460
32
Little Rock Ar.
My antenna cable leading to my radio was cut. Does anyone know whether or not I can splice the cable back and make it work.
Possible - yes, easy - no.
You will be better to just replace the antenna. They are very difficult to repair and keep signal integrity.
i spliced mine the redneck way with black tape...works fine. just peeled the shield back and connected the center conductors together...taped that...then used foil tape to connect the shields. works great and good signal.
Simple XM player
channel idea
