D-10 Channel Guide Filter | SatelliteGuys.US
BgSat
5
I am new to D*TV.
Is there any way to "filter" the channel guide listing on my D-10 receiver? With D*network I was able to set the guide to show only those channels that are available with the package I purchased.
Thanks!
You can do this under favorites. I do not have a D10 handy and I don't remember which setup menu these are under but like other D* receivers there are favorites for up to 4 users in your home. Hope this helps!
Hi Mike,
I am familiar with the favorites menu item. Do you mean that I have to scroll thru and select all of the channels that I want in the guide and assign them to a favorite list?
With the previous service/receiver, I could simply select a checkbox and only those channels included in the package were displayed. I would be interested in finding out if this 'feature' is available with the D-10...
boba said:
No there is no "all sub" option on the D-10. The correct abreviation for DISH Network is E*.
Correct, but you can customize the guide by favorites as with all D* receivers, so while not built in, you can do it yourself.
Signal Loss With New Dish
Hughes DVR80 - Utterly confused
