D-10 software Problem? | SatelliteGuys.US
cueman98
85
Cocoa, Florida
Hi all,
just wondering if there has been a software "update" for D-10's recently. my program guide is not working as normal. If I'm watching a channel,then go to the guide and select another channel to tune in, the guide disapppears,but the screen stays black. also if i come out of the guide without doing anything, the picture freezes for a second then continues. I've tried resetting, but it only fixes the problem temporarily.
Any advice is appreciated.
You are not alone...
I have a D-10 200 and it was updated only a few days ago since then I have had two problems that were not there before
The picture freezes upon intro and exit of the guide
when selecting a channel from the guide the guide will disappear but the screen remains black
sometimes the audio comes in but the picture never does, you have to either type in the channel number or use the channel up down buttons to "surf" to the correct channel for the picture to come in
D10-100 = ?
D10-200 = 1004
D10-300= 100A
They've all had updates recently to fix a problem with the access cards. Wait until another update, or just get a D-11.
DirecTV wants Echostar but sees regulatory hurdles
MyDirectTV News for April
