D1000 vs D500? | SatelliteGuys.US
D1000 vs D500?
ajohnson
168
Riverside, CA
Pretty sure I've seen enough messages that say it's better to use two D500's to get 110/119 & 129 vs a D1000, but I thought I'd make sure. I swung my 148 dish to 129, but I'm a crazy fellow and was wondering if down the line I might miss out on something at 148 or 61.5 (or even some other slot that doesn't exist yet). Would it be better signal wise to get a D1000 and re-aim my other dish back at 148 (or 61.5) or get a 3rd D500?
The way I see it, theres more flexibility with 3 dishes in case I decide to choose other satellites, but my wife might make me sleep on the couch.
If I get a D1000, I might even be able to sneak it on there without her noticing, and if I convice Dish that I have one, it may make my future CSR experiences simpler (knock on wood). I wouldn't be surprised if Dish insists on sending me a D1000 if/when I upgrade to a 622.
Course I may just leave well enough alone for now.
I have found that a dish 500 for 110/119 and a dish 500 for 129 is more stable for signal with higher signal #s.
As far as a dish 1000 goes it is a good dish but there has been a lot of treads on signal srength being very low as trying to put 3 sat locations on a small dish you kind of have to find the middle of the road for signal strength.
but again it is a matter of were you are a lot of pepole have gotten good results with there dish 1000's so i guess it is up to you, and haveing a extra dish does give ya a chance to move sats around if you like .
but remember 1 thing it dont matter how you get the signal 1 ,2 or 3 dishs as long as you get good signal you will have less problems in the long run.
811 P3.34 Software Question
211 vs. 622
