D11 Need Help Getting To Signal Strength Scren | SatelliteGuys.US
Stargazer
16,568
340
Western WV
There are a few D11 satellite receivers that I have had trouble accessing the signal screen. It says acquiring satellite but even if I get a signal with another older box it still says that on this one. My guess is that the setting is for the oval or slimline dish and it is not for the round dish so it is not acquiring it. How can I access the menu to get to signal strength screen when it does this? Another D11 box that someone else had I had the same issue but once in a while I was able to press a bunch of buttons and get to the menu so that I could change it to round dish and tune in the signal.
Try Exit, menu.
I know on my D12 when I first power it on if it doesn't have signal or I need to change the satellite setup (camping usually) I have to wait about 10-15 mintues before I can get the full menu screen options.
Thats a stupid feature that you have to wait. When I was playing musical dishes I used an old Hughes receiver I have to get on bird well. Then I hooked up my D-11 and peaked the dish.
Also the old receivers booted and came up in a flash the new ones take some time.
New HR-24
Kudo's to Directv
