D12-500 swim fix | SatelliteGuys.US
D12-500 swim fix
thetech2009
281
dallas
This download should correct the issues with banner not matching programming with SWM systems.
Date Product SW Version
Thu, Sep 24 D12-500 x1194
This will conclude the rollout of this software to the D12-500
Thanks thetech2009,
Your fixit post are very helpful to me!:cool:
I have one and the issue is annoying. Just wondering cause I am new at D*. I have to wait till Sept 24th to get the update? or can it be force now??
I would force with the 02468 on remote at boot up?
TIA
jet
Thanks thetech2009,
TIA
jet
yes that is how you would force it. that software like my post said will not be ready untill the 24th, that was sent to us from directv to give us a heads up that they finally got the software fixed.
Thanks again thetech2009,
So far leaving the power on, The issue seems to be ok. Well almost. Just plain tired of rebooting!
I will force the update after work tomorrow evening.
jet
jet
red button reset will not work for this problem,well it will for a bit. unplug it completly from the power for 15-20secs this should last longer. and tomorrow is the 23rd so that will not do any good, the download will probably happen itself thursday morning around 2 or 3. if not then i would try the force
Sorry I was doing the power off on front panel. Unplug for a few minutes and plugging back in again. That is reseting not rebooting??? Correct?
So Thursday afternoon it is then.:)
jet
New Method of Transmitting Locals?
Slimline LNB question
