T This1 SatelliteGuys Pro Original poster May 27, 2009 261 1 Florida Feb 23, 2010 #1 Can you daisy chain these if you need more ports. I am guesing that is what flex port are for
rad Supporting Founder Supporting Founder Lifetime Supporter Cutting Edge Sep 7, 2003 11,648 6,130 Dripping Springs, TX Feb 23, 2010 #2 This1 said: Can you daisy chain these if you need more ports. I am guesing that is what flex port are for Click to expand... No, you can't daisy chain them, the flex ports are for other satellite positions. What you can do is get four wide band splitters and split the feed from the LNB to feed two WB68's.
sddtvtech SatelliteGuys Pro Sep 17, 2009 1,202 0 in a van down by the river Feb 23, 2010 #4 you can use a power splitter before the dish to the switch... then ud have a 16 out switch. one line to the power splitter will give you two into two switches.. is that what you are looking for? thats the easiest way to do to get 16 tuner outs.
