Daisy-Chaining 721 to a 6000 | SatelliteGuys.US
dimi1963
268
Union, NJ
I was wondering if it is possible to daisy chain the 721 DVR receiver to the 6000 with only one feed from the dish. If so how do I go by connecting it? I know it will not be possible to recored HD broadcsats. CAn I just get the SD out from the 6000 to the in connetion of the 721?
Thank you :confused:
You cannot daisy chain the units, but you can use them both hooked up to your HDTV. In fact I did before going with the 921. You can also sell your two units on eBay to help pay for the 921 (which is far better than a 721/6000 combo) or run three lines to your two units and hook up the 721 to your TV's s-video inputs and the 6000 to the TV using the component input. I hope this answers your question.
How to tell if receiver is getting old
Combine OTA signal(in) with 522 TV2 out on a single cable
