Please provide feed back on this channel in the DC area if you are having trouble receiving it as VOOM is trying to find out if there is indeed a problem. Do not remember if anyone mentioned this before.
FYI, WTTG-DT maps correctly on all my receivers (Mits, Sony, Samsung, VOOM), but this channel will frequenly lock-up my VOOM receivers when displaying the signal level. Due to their low DTV antenna height and my location from the tower (55+ miles), their signal level is often borderline (83-87) during the winter months.Originally posted by nabsltd
I examined my Super Bowl recording tonight, and I think I see some reasons why people are having PSIP and mapping problems. There are four sub-channels in the main table (PAT or PMT...I can never remember which), but only the "main" one has enough in the other tables to allow it to be recognized by the MyHD card (which is notoriously good at these things). HDTV2MPEG2 says that there are the following sub-channels:
There are no audio tracks to go with the last 3 sub-channels.Code:Name video PID audio PID WTTG-DT 5.1 0x21 0x24 WTTG-DT 5.1 0x21 0x100 WTTG-DT 5.1 0x21 0x101 WTTG-DT 5.1 0x21 0x104
They are also messing up the header that tells the bit rate. The actual rate for the channel is 14.09Mbps, but the header says 19.00 Mbps.
Limited time offer
