Dead 6000 | SatelliteGuys.US
Dead 6000
if it doesn't power up at all then check with freetech for warrenty
if the loader isn't seeing the coolsat 6000 then check and see if you are using the correct cable & correct com port
Need help with installation
Developed a small problem with my DVB setup.
