Penquinbrat, I get the same from time to time as well as a line down the center of the picture. Bringing up the guide usually doesn't help with either of those abberations but I just shut off the STB and turn it back on and it goes away. The problem seems to be in the STB, probably a software issue, as I didn't have it before the last upgrade. I am just hoping that if/when Voom continues, we get a software upgrade that will correct the issue. Also, for those that are reading this, the problem was noticed before the new harmonic encoders were in place, so that is most likely not the problem.
