DECA install | SatelliteGuys.US
DECA install
SatguysJerry
2
Ohio
Just been installed with new receivers from Direct TV with Whole Home DVR. Direct will be adding the DECA this week. I want to make sure my wiring is ran before install.
How far can the router be from the Coax power unit? I have a ethernet cable at my main tv that is approx 50 feet from router, can the coax be ran from the Direct splitter to that point to get the ethernet feed? This coax run would be a simple run. If I have to run a coax to the router location, it will not be simple.
Please advise what will work.
Thanks for the reply, just to clarify; all the DECA needs is a internet connection to my router for service?
Running the coax from the Direct splitter to the main tv location will be very simple so I will run that cable just to make sure all runs from splitter are direct.
thanks again
Search by Program Name
Online DVR Scheduling
