Declination 12 ft tek2000 | SatelliteGuys.US
espaun206
93
15
Guatemala
Hello
I lost the one of the pieces L
declination of my antenna, it's mid 2017
I would like to place one like this type ball joint of antenna, know what this type of nuts is called or where can I get it
this is tek 2000
now in tek 2000 they only sell this new model as it is only compatible for 2018 models an 19
you know how it helps to have these two
screw thread instead of one
new model
If your wanting a bolt like in the first photo... get a rod end bolt. A regular bolt passes thru the loop. Google for the measurements you need.
Similar to an eye bolt but stronger.
