Declination adjustment on dish | SatelliteGuys.US
pdiddy
158
31
western montana
I noticed on my 10ft channel master dish there is no declination adjustment,only an elevation adjustment.My other 10 footer has both.What gives???
What gives? Dunno. can't see what you see.
Let 'us' [members here] take a look. Post a bunch of pictures.
Might be like Birdview, where you use washers between the dish and mount???????
Yeah there has to be some way to adjust the declination.
Pictures Please :)
Thanks for responding,after closer inspection there is a slot on the top part of the ring mount that has a slot where you can fine tune the declination,I feel like a fool for not seeing it.Again thanks for responding.My other dishes are a little different.
Bending Pole
switches and multi-satellite switches
