Whats the primary difference between a deep dish like this 10 footer and a shallow dish like the one shown? Other than size does one perform better than the other? I understand the focal points will be different between the two.
This is the feed horn that was on the deep dish. It does not look like the standard setup. Off center next to the C-band element is the KU element. It appears that the KU side has a fixed polarity. I was planning on mounting a standard scalar ring and feed, but according to Likvid that may not work.
I may have to modify the existing scalar ring by removing the center section and sliding in a new feedhorn such as a BSC621.
I am thinking about setting up the deep dish next to the existing 10ft Unimesh dish and performing several A/B tests. The loser goes back to the barn.
I removed the center section of foam. Interesting, the KU pickup is right up front and the C-band is further back. Both elements are connected together and turn for polarity.
Limited time offer
