I have a HR54-200 and a C61K-700. The new firmware came in last week. When I turn on my 4K television, there is a a 7 second delay then it goes blank again for about 2 seconds when I first turn it on. Is there anything that can be done about this?
Yeh this started with the last two mini firmwares. Fb7 was a 20 sec delay. FBA is now 7. Hopefully it will keep getting shorterWhat firmware do you have on the Genie and client?
My Client is 0xfba and the Genie is is 0xffc. This morning it took about 15 seconds to start up, the guide info then showed with the screen still black, then it all went black for a second, and then the picture came on. When I change the station there is a few second delay with the banner coming on then the picture starts. My main TV with the Client is Samsung UN55KS9000 if that has anything to do with it.
I have 2 of these. they work fine in 2 of my rooms, but in my master bedroom, I've tried both and each have the same glitch of skipping/freezing for 1-2 seconds about every 15-20 minutes. does this mean it's likely the coaxial running to that room that is the issue? I have a H25 receiver that mainly gets used in my master bedroom. It never has problems. if the coaxial was the cause, then I would assume the H25 would also have a similar glitch.
thoughts?
the same coaxial connection I use with the flawless H25 is the same one I used with the C61 in my master bedroom that had the glitches. the only thing abnormal I see is the coax coming out of the wall outlet is not flush. I can pull the cable from the wall plate. No idea if that could be the issue.Just asking? are you using the same "CABLES" for Connections all the time? (excluding) the RG6? Is it possible that in that room -the TV settings are Different? just some idea's throwing out there.
It could be a Lose RG6 Connection (wall Plate) or elsewhere that could only effect the mini's?
Being that every box does the same (fail) in that room - It's NOT the "box" if they work every where else.
You can test your Coax Network as well
what are chances I can convince directv to come out and re-run a new coax line to my master bedroom...without too much convincing? I know if I call in, they're going to tell me to reboot the box, etc. and do the other stuff I know does not work.
I have a tech coming next Saturday to run a new coax to my master BR. if I somehow continue to have issues with the C61 wired, would my next best option be to get a wireless mini?
Limited time offer
