Deleted Satellites -VP211 | SatelliteGuys.US
danger626
2
Colorado
I accidentally deleted all the satellites from my VP211. Now if i try to check switch it shows only an X satellite box. 110,119 & 129 have been removed. Is there any way to re-port the satellites?
They don't show back up. After check switch is finished it says there is a problem with the system and prompts if I want to check switch again. I've done it numerous times and the satellites do not show up.
Since you can't manually "delete" (nor "add") satellites, I suspect that your LNB or the cable between it and receiver has failed.
you have standard troubles... Call dish and request a tech
Clear the switch matrix and see if that helps.
Disconnect the satellite feed and run check switch. Let it finish until it shows all Xs.
Connect the satellite feed back and run check switch.
If you still get the Xs, you got a problem with your dish, lnb or cabling.
Ancient Dish Receiver Going or Something Else?
Poll: What Other New HD Do You Want to See?
