Deleting files on the DVR | SatelliteGuys.US
Mr Tony
3,359
14,739
Mankato, MN
I noticed when deleting files on the DVR you have to do them one at a time. So you find the file, hit yellow button to delete and it then kicks you back to the channel you were on.
Any way to have it where you can delete more than one file at a time?
I thought that was an "Undocumented Feature" {Microsoft's term for a bug they did not want to fix.}
Actually, I liked it that way because I can check each file, delete it if I want to and go to the next.
If you can safely delete with the PC then a group delete on the PC would be great. I am going to check that and then do a defrag, and see it the files still work on the STB. I have had problems with the DVR1100c, not liking that, but AGAIN it may be my dirty power. The 12VDC will clean up the power problem.
microHD Promo
i am using diseq 1.2 on my solomend and azbox
