deleting satellites on Pansat 2500A | SatelliteGuys.US
TuxCoder
Collector of Space Beams
2,052
3
Dayton, OH
Apparently deleting any built-in satellite on the 2500A doesn't actually delete it, but just hides it from the list in the antenna setup menu? The reason I ask is, I've noticed I can't add more than 2 or 3 new satellites, even after deleting several I don't need. The unit supports 60 satellites but its built-in list contains almost as many already. Am I doing something wrong?
the ones that are c-band, I go in and rename them
Took G11 C and renamed it SBS6 :)
you have to change the parameters in the install screen, but it works :D
