Device to move and combine 2 5mhz-1ghz signals?? | SatelliteGuys.US
  • Thread starter Thread starter philhu
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
philhu
1,215
Cold Boston Area
Hi
I want to be able to put antenna and cable on one rg-6 wire.
The device would move the band (like the old directtv box called a 'signal stacker')
Band 1 in the normal range
add 1ghz to band 2 so it would be in 1.05-2ghz
Obviously not cheap, but definitely doable.
Anyone know of such a box?
Directtv had one years ago that allowed 101 and 119 satellites to be on the same wire. It required power at one end and moved a set of sat signals up the spectrum and then back down.
The description of it from way back is at:
http://www.9thtee.com/dssstuff.htm
I have pne but the bands it moves are wrong for cable (950-1450, calbe is 5-1000) and it alternates the 12/17 volts for sat rcvrs polarity, probably not good for cable rcvrs.
But is there a current solution to put antenna and cable on one wire?
