DFW - 49% error on PBS KERA-HD | SatelliteGuys.US
snathanb
2,580
4
DFW
I've been able to get PBS on my 811 until today, and now I am getting the dreaded 49% error. Channel 11, which is on the same broadcast tower, is coming in fine.
Can anyone in DFW with an 811 confirm reception of KERA (13.1)? I know it worked on Friday. My antenna is up in the attic, so it hasn't moved, and I am still getting every other station.
Seen it.
I've gotten the same error, but after the 266 software update i've found that if I step off, one channel, and then step back, I get the channel to lock in. Try it and let me know if that works for you.
Regards
Nope...tried a bunch of other tricks I read about, as well.
Could be a temporary signal problem, just want to see if anyone else in Dallas was seeing it on that channel.
I got it back.. but it is still missing it's PSIP remap.. I think they must be playing with the settings at the station... all is good.
Even got a new channel out of it when I did the rescan... now getting 18 stations, 25 channels of digital TV.
Too bad I don't speak spanish... but I do find it amusing that while some areas don't even have the big 4 on, we have 18 stations broadcasting in digital in dallas, even all the little independents.
PSIP is back now, too. Station difficulties.
I too had the same problems.
I had to reboot to get the remap back. When it came back it was mapped to 14-01 and not 13-01. I went into the setup for locals and it showed 13-01. I saved it then it showed up on the guide correct.
The 811 is a nothing but a bucket of bolts.
HOW TO: Edit All Sub/All Chan Lists, View only Sub Chan in Themes
Just Installed Dish and?
