Can someone please give me a brief explanation of the difference between getting a H24 and a C31(mini-geni client), for a second t.v. I have one genie right now, and am not totally sure about what is the difference between the two. Thanx!
The basic difference is the C31 doesn't have it's own tuner, it uses one from the HR34. An H24 does have it's own tuner.
The HR34 requires a swm type setup and has five tuners of it's own. If you have a complex setup with other dvrs or receivers, you might have to upgrade the wiring if there are more than eight tuners. Also, for now, the C31 has more control over recordings on the HR34, but that's supposed to change with a software upgrade at some point. There may be other reasons, but that's about all I am aware of.
If I may ask, why would a person choose one over the other, I am confused there.
One thing I thought of was this, if your hr-34 were to die, I believe you lose the use of the mini-geni(c31), but if I am correct the H34 would continue to be able to watch t.v., am I thinking correctly on that??
H24 ordered thru solid signal![]()
Seeing you already have a DVR, I would have went for the HR24 instead if you swing the money.
An H24 is a receiver and the lease fee is around $100. The HR24 is a dvr and will run you around $200 to lease. Those amounts are just to get the box, the monthly fees would be the same since you already pay a dvr account fee.
Hey, you'll have to excuse my ignorance, I am not sure what you mean, could you explain, thanks
Good enough reason then not to get another dvr.
Thanks for the info, I live in Columbus by the way, GO BUCKS!!!!Personally, if you can swing it and you already pay for the DVR function, theres NO reason to NOT get a DVR along with your next recvr in my opinion, your already paying for the DVR functions, you can never have too many recording devices available ....
Jmo.
Limited time offer
