Difference between AU9-S SWM dish and non AU9 SWM | SatelliteGuys.US
Maybe between manufacturers the mounting holes are different. Other than that, the differences would have to be slight if the lnbs are interchangeable.
Thanks Chip. From what I can see, the Chicago market wouldn't need the 5 lnb dish is that correct? Would the 3 lnb dish work fine?
Yes, the 3lnb is what you want. The local sd channels in Chicago are on 101, so you don't need to get 119.
Question About Converting to SWM
Sound drop outs
