Different signal strength readings... | SatelliteGuys.US
igator99
569
from different recievers. I assume that going through a multiswitch you will lose some signal strength. I have one line running straight from the lnb and I get 95 plus on 101,110 and 119. The other receviers running through the multiswitch are below 95 but still above 90 percent.
igator99 said:
from different recievers. I assume that going through a multiswitch you will lose siganl strength
For once ASSUME won't make an A** out of U and ME. you're correct you will lose some, length of cable and whether or not there are some barrels in the line, play a big part in the sig too.
Need help, DTV customer since 95 at a very
Looking for installer in Raleigh NC
